BSA B50 ‘Gold Star’ 500SS
Re: BSA B50 ‘Gold Star’ 500SS
Postby Lotus54 » Sun Oct 27, 2024 8:07 pm
I still have not painted it. Too many projects!
Postby Lotus54 » Thu Mar 27, 2025 5:12 pm
I ordered a Vape electronic ignition for BSA.
I’m getting close to having time to work on it again- that was high on the list.
Postby John H » Sun Mar 30, 2025 11:25 am
Is the new ignition a 'Wassell Vape' unit or strictly a Vape? Seems to be two different units.
Postby Lotus54 » Sun Mar 30, 2025 1:28 pm
I think a Vape, ‘by Wassell’.
I don’t think Vape sells one directly. Perhaps has some parts to make fit from Wassell?
Postby John H » Sun Mar 30, 2025 4:34 pm
The Vape on my Bul came directly from the mfg in Czech Republic. George just received one for a Husky. Shipping was about $35.00 and the price was much cheaper than from US/UK dealers.
Postby Lotus54 » Mon Mar 31, 2025 6:15 am
I have gotten several direct also. But they do not have one listed for the B50.
I have one on Benelli 175, Benelli 250 twin, did another for Will on his 250 twin.
All with no battery but full lights.
Postby John H » Wed Apr 09, 2025 7:17 am
Have you had time to install the Vape and try it out? I may have to get one for my DBD 34 as the old mag is in pretty bad condition.
Postby Lotus54 » Thu Apr 10, 2025 6:44 am
John H wrote:Have you had time to install the Vape and try it out? I may have to get one for my DBD 34 as the old mag is in pretty bad condition.
I just put the BSA on the lift and ready to start. I had some other things to take care of first. Still going to be a day or two before I really start I think, but close.
I will try to take some pictures as I do it and documentation of wiring etc. The manual only shows how to do twins.
Postby Lotus54 » Fri Apr 25, 2025 7:11 am
I got the points plate and advance mechanism removed. The replacement rotor/magnet is a taper fit also, so needs to be installed with proper timing. (Or pretty close, I think some adjustment on the plate it possible).
Trying to figure a way to mount a degree wheel was interesting. If primary case was off it would be pretty easy to use the rotor mounting nut. But I don’t want to remove all that just to set timing. So I designed a nut that would be a tight fit over the big rotor nut- then have a threaded part sticking out. The degree wheel will slip over that and another nut on the outside.
I am 3D printing it right now in PETG CF. I think it will be strong enough to turn it as long as sparking plug is out and I do not tighten the degree wheel holding nut down too much. Time will tell.
I will take some pictures of the part in place, since it likely doesn’t make a lot of sense.
Postby Lotus54 » Sat Apr 26, 2025 9:54 am
This is first one- I made it a bit longer for second to make easier to put a wrench on. First try printing open wrench flexed too much- so I will make an enclosed one I think.
