Aermacchi 175
Aermacchi 175
Postby Lotus54 » Sat Nov 02, 2024 8:28 pm
A 75 Aermacchi (Harley) 175 SX came my way. I have been getting it back to usable condition.
The rear rim was really bad, so I (foolishly) replaced with a new Borrani alloy with Stainless spokes/nipples. Front was usable. New tyres, tubes etc. I have some replacement forks that I will replace seals (original tubes were pretty rusty).
No idea what I’m going to do with it, but it has been fun fixing it up.
Re: Aermacchi 175
Postby Lotus54 » Sun Nov 03, 2024 10:23 am
Here is a photo (Latest update changed how to resize)
Re: Aermacchi 175
Postby John H » Sun Nov 03, 2024 9:42 pm
The front wheel must match the rear. Oh no, here we go...again. Ha. We're addicted. I'm tempted to put the quick change alloy wheel you vapor honed for me on the TR6. But that would mean I would have to do one for the front. Not going to happen..
Re: Aermacchi 175
Postby Lotus54 » Mon Nov 04, 2024 5:51 am
I have replaced the oil injection hoses since they were not flexible at all anymore and seal on oil tank in frame was bad.
Next I will run it with pre-mix for awhile while holding pump throttle arm wide open.
After running, I will put back on lift the other way so I can swap the forks. The fuel tank is mostly cleaned out and almost ready for Caswell.
Re: Aermacchi 175
Postby Lotus54 » Mon Nov 04, 2024 9:10 am
John H wrote:The front wheel must match the rear. Oh no, here we go...again. Ha. We're addicted. I'm tempted to put the quick change alloy wheel you vapor honed for me on the TR6. But that would mean I would have to do one for the front. Not going to happen..
Yes- I agree! It is a problem. But is certainly is fun to make them as good as possible.
I could have saved a fair amount using a Sun rim- or just a steel one. But heck- as long as doing it, may as well overdo it.
Re: Aermacchi 175
Postby Lotus54 » Mon Nov 04, 2024 5:57 pm
I ran the Aermacchi for awhile today with 50:1, while holding the Oil Injection pump arm on full. That way I could watch the hose to the intake fill up.
It runs well, but I will need to check regulator- voltage seemed a bit high.
Now on to the forks.
Re: Aermacchi 175
Postby Lotus54 » Sun Dec 15, 2024 7:56 am
I had the forks all cleaned up and ready to reassemble. Then I found the Betor seals I had were different for these than the ‘normal’ Betors I have had on lots of bikes. Aermacchi must have specified a slightly different (and sort of odd) size over the regular ones. I cannot really see a reason why, but I’m sure they had one.
So I ordered new seals, but have had too many other projects going to put forks back together and pop on the bike.
Work on a 1990 Autozam Scrum (Japanese mini-truck)-rebuilding the 660cc 12valve three cylinder engine. Valves were pretty worn, but kit I got had new ones. Guides were fine so I did not replace. I kept original con-rods too, since I thought they were better than the replacements and I saw no indication of them being bent. Manual calls for piston replacement every 100,000 kilometers (and this has 108), plus I figured the rings in the kit would be more likely to property fit the new pistons.
